First Build Amd Wont Boot
Manny805
Hi i'm new here need some help this is my first amd build.i already install the mobo,cpu,hdd,ram,video card,cd-r drive hooked all cables as manual said and i tryed to boot it up and it wouldnt boot.so im here for some help to see why this new build amd wont work any advice ? here is a list of my parts...
1.eVGA 256-A8-N313-LX Geforce FX5500 256MB DDR AGP 4X/8X Video Card - Retail
2.Kingston ValueRAM 512MB 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered System Memory Model 3.KVR400X64C3A/512 - Retail
4.AMD Athlon 64 3000+ Venice 2000MHz HT Socket 939 Processor Model ADA3000BPBOX - Retail
5.Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
6.ViewSonic VX922 Black/Silver 19" 2ms LCD Monitor - Retail
7.LITE-ON Combo Drive Black ATAPI/E-IDE Model SOHC-5236V-61 - OEM
8.ASPIRE X-Dreamer ATXB3KLW-BK/420W Black Steel ATX Mid Tower Computer Case ATX 420W power supply for AMD/Intel Power Supply - Retail
9.ASUS A8V Socket 939 VIA K8T800 Pro ATX AMD Motherboard - Retail
Thanks in advance.
Uninstall everything except mobo, CPU, memory, and video card. Connect the video card to the monitor. Make sure the power cable is plugged into the PSU and to an active outlet. Set the switch on the back of the PSU to "I" and not "O", and also change the voltage switch (if it's there) to the proper voltage. Tell us what happens when you press the power switch (do connect the case wires to the mobo).
ok it powers up now,but no video monitor is just black.power light is green the loading light is also on witch is red.what can it be now ?? also theres no beeps from the speaker.
I'd take it out of the case and try powering up with only the mobo, ram, cpu, and vid card. Check for any shorts if it does post.
