First Budget Build
Cod
Kids' homework, software development (including graphics programming), 2D work w/ GIMP, Inkscape, etc., limited 3D w/ Maya or Blender, possibly animation in the future
~$600 USD (would like to stay lower if possible)
Honolulu, HI, USA
CPU, Mobo, PSU, GPU (not a workstation card), SSD
- Corsair 330R case
- 8GB Corsair Vengeance RAM
- 1TB Seagate HDD
- Blu-Ray Reader
6) Will you be overclocking?
Nope
2 x 23" monitors (currently 1920 x 1080); however, will be upgrading soon
NLT September
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Nothing that current motherboards are lacking.
64-bit Windows 7 Professional, 64-bit Windows 8.1 Professional, any Linux distro
Of note, I'm not a "fan boy" of either Intel or AMD. I've never owned an AMD processor, just GPU. Any thoughts / advice is greatly appreciated as this will be my first budget build.
Thanks!
Honolulu, HI, USA
Please tell us if tax/shipping are included in the budget. Last time I checked, it's expensive to ship to Hawaii.
Also, since you are not requesting a professional graphics card, do you have any tools in your pipeline that a Cuda-only? Otherwise you can use anything.
And do you game AT ALL? And is 3D modeling a priority?
If nobody has helped you yet, I'll attempt a build when I get home.
I can go a little higher to cover shipping cost; however, shipping out here isn't too bad if you have more than one item. Also, only Newegg has "outrageous" shipping prices for here. If worst comes to worst, I can ship to a family member and pay them to ship to me. The budget isn't really a budget, its a wife restriction :)
No Cuda-only things. I've been looking at the R7 270's.
The only gaming that will be done on this computer is by my kids. They don't play anything a 270 couldn't handle easily.
Thanks for offering to help. In the past, my budget was a lot higher for builds (primarily my gaming rig).
Okay dude, got you all the parts through Amazon to avoid big shipping hit:
Core i5 4430 - $185
http://www.amazon.com/Intel-i5-4430...id=1407276614&sr=8-2&keywords=core+i5+haswell
Gigabyte H97 MicroATX: $90
http://www.amazon.com/Gigabyte-Grap...id=1407276781&sr=8-1&keywords=h97+motherboard
Corsair CX500: $55
http://www.amazon.com/Corsair-Build...F8&qid=1407276913&sr=8-5&keywords=corsair+psu
MSI R9 270 Gaming: $170
http://www.amazon.com/MSI-Computer-...TF8&qid=1407277252&sr=8-2&keywords=amd+R9+270
Crucial MX100 256GB: $108
http://www.amazon.com/Crucial-MX100...F8&qid=1407277032&sr=8-1&keywords=mx100+256gb
Total: about $600 before shipping.
If you must cut because the shipping adds too much, I would suggest an older B85 motherboard. You can also save 12 bucks with the 430w version of the PSU I picked. See those alternatives here:
http://www.amazon.com/Corsair-Build...&qid=1407278117&sr=8-1&keywords=corsair+cx430
http://www.amazon.com/MSI-Computer-...7278170&sr=8-8&keywords=gigabyte+b85+microatx
Thanks! I'll take a look at everything when I get home from work.
There's only one change I would make to defaultluser's build: I recommend spending the extra $5 for the XFX 550W due to its significantly higher quality:
$60 - XFX TS Series XFX TS 550W PSU
Good suggestion!
Based upon the forum discussions I could dig up, that's a potentially excellent upgrade over the Corsair in terms of quality, but I would really like a full-on review from someone reputable to be sure before I start recommending this myself.
It's a shame that they've made what seems like a real quality push for these latest Seasponic-built PSUs, but have not bothered to send them out for any major reviews. But their older entry-level Seasonic-built PSUs have not been perfect either:
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story4&reid=225
Is the TS reeally better? I would like to know. I'd rather recommend the CX with the lower-quality capacitors (*could* die early, but that's all) than something that could potentially have voltages way out of spec.
Good suggestion!
The TS, from what I can tell, is actually a renamed Core Edition 550W, the same one in that JG review.
While the XFX does have some wonky +12V regulation, overall, its quality of parts are better and it should be rated at a higher temperature (40C) than the CX500 (30C). I've never seen any Seasonic design rated for less than 40C.
Okay, I'll agree with the recommendation. Even though those voltages look a bit wonky, they're still within spec, and the rest of the PSU build looks quite good :D
