Well, I now came to the point where I finally want/have to build a Server/DSS.
Right now I have all my media like movies, music, pictures spread across different computers. I want to have a clean solution and put all that stuff onto onto one machine, so that it is accessible from everywhere in the house like living room (htpc), etc.
I already made some resarch and came to the conclusion that its gonna be hardware raid5 and Im gonna use 6 WD 500GB drives which will give me around 2.5TB.
The parts I have in my mind are:
Raid Card
3WARE AMCC STORAGE 9500S-12 SATA RAID CONTROLLER
http://www.3ware.com/products/serial_ata9000.asp
maybe i can get it for $250
6 of the ports will be used, so i have another 6 free in case im running out of space.
Mobo
Asus P5KPL-VM
http://www.asus.com/products.aspx?l1=3&l2=11&l3=563&l4=0&model=1772&modelmenu=1
$80
CPU
Intel Celeron 430, 1.8GHz BOX, 800MHz FSB, Socket LGA775
$50
Ram
Kingston ValueRAM, 2x512MB Kit, DDR2-667MHz, CL5
$30
Thats all the additional stuff I need. I alread got the Tower, HDDs, PSU and so on
Know to the questions.
1.
I heard 3ware is pretty good and this card has alot of ports and it should accommodate my needs (enough ports for a later upgrade, i have a second array in mind), thats why I have chosen this one.
What gives a bit of headache is the weird connection layout, looks like to PCIe ports behind each other, well ive read it fits and works with PCIe ports and in the manual it says pci 2.2 compliant. But Im not one hundred percent sure if its really fits and works on this http://www.asus.com/products.aspx?l1=3&l2=11&l3=563&l4=0&model=1772&modelmenu=1"]mobo
2.
The hard drives Im gonna use are all WesternDigital 500GB 7200rpm ones. They have all the same size but probabely arent the same model since ive bought them over the course of nearly 1 year. Does this even matter?
3.
I read about this Time-Limited Error Recovery (TLER), so I guess I have to enable it first with WDTLER utility on all of the drives I need for the array?
4.
For which OS should I go? I heard FreeBSD should be good (and free). But since Im a Linux noob I dont know if I should dare to use it.
5.
What do you think in general about this setup?
Thats it for now, thx for your help
cheers
Raid Card
Mobo
Asus P5KPL-VM
$80
CPU
$50
Ram
$30
1.
2.
3.
4.
5.
cheers
