First attempt on a serious OC *need tips*
Ghost$nipa
Hardware:
E6600
Abit Fatal1ty in9 650i chipset SLI
Kingston Hyper 5-5-5-18 (1066 rated speed) 2.30 V
250 GTS
BFG 650W PSU
If i touch the multiplier it wont boot peroid. Left it at stock "9".
PCI set to 33.33 and PCI-E set to 100
E6600 at 1.412 V OC to 3.4 speed 378x4 @1512
Temp at Idle 51C MAX load at 63C
Currently using Unlinked mode....If I use sync, dividers or linked it forces a lower OC.
NB voltage from 1.2v to 1.43V
Memory at 2.30 volts with looser timing of 6-6-6-22. Speed currently at 520x2 = 1040 speed.
I noticed that the memory can't run at it's rated speed timing so I was forced to loosen the timing. I haven't tried to focus on lowering the memory timing.
Anything lower with voltage will either crash before boot or prime fail. I tried to lower all voltage such as CPU, VTT and NB....what else can I do? I could install some small fan on NB and use some silver paste on all silicon chips?
I am trying to save some money and skip out on the current platforms until I am ready to upgrade.
