I have been wanting to get into it for a while but I never did. Now that I have I don't think I'll ever go back to air cooling. Well....as long as nothing leaks and fucks up.
Anyhoo on with it.
CM Wavemaster
D4 pump
RBX block
1/2" everything/ Tygon/water wetter
T config
dual 80mm radiator(I would love to use a cheap heatercore that performed just as well if not better but I didn't want a blowhole config. Not much fits in a wavemaster)
I'm going to move the pump out a little so the tline isn't in the way so much. I left the tube long because I'm not sure if I want to use the filler cap yet. I might just cut it pretty short and cap it off. In the front I'm going to put some foam in front of the radiator so it brings in air through the holes on the front face of the case and not from the cracks going inside the case.
Anyone see anything that needs some improvement? My p4 3.0C is running at 3.75 with a 32C temp at full load with this setup, so I'm pretty satisfied.
Anyhoo on with it.
CM Wavemaster
D4 pump
RBX block
T config
