First AMD Build gone awry
DarkStar02
Well, I finally got my processor today and I'm ready to throw my system together. I opened up the CPU which I got used for cheap with a nice stepping- except when I open the box everything is all messed up. The cardboard packaging is all torn up and there is cardboard dust everywhere. I find the processor which is sitting on top of all the cardboard and pull it out. Then I pull out the processor which has cardboard dust all on the thermal pad. I pull it out and wipe off all the dust. Hoping the CPU isn't DOA, I stick it in my motherboard. It takes me like 10 minutes to get the heatsink on because I'm retarded, but I finally get it on and I boot up. WOOT! The LanParty NF4 logo flashes onto the screen! Then the computer gets quiet... What? I drop to my knees and look in the side of the case. The CPU fan has stopped spinning. I flip out and turn off the computer. I make sure everything is connected then I turn it on again. Same thing. The fan starts spinning again though after a 3-4 second pause. Great! I look up at the screen. It's stuck at the LB Nf4 logo though. I turn the power off and remove the video card, thinking that it might not be making full contact due to the oversized chipset fan in the way. I also pull out a stick of RAM and then put the video card back in as far as it will go. I turn the system on and now there is no picture. Oh boy. I turn the computer off and look around. Whoops, I notice that I don't have the regular 4 prong power cord plugged into the motherboard, hope it didn't screw anything up. I try it again- no picture. I get on the computer and start looking for help. I come to the DFI-street forum, and click on the sticky where it shows how to set up a computer with an Athlon 3200+, etc. I realize that I didn't plug in the other power cord going to the motherboard. I get off the computer, plug that cord in, and try again. Nope, still don't have a picture.
Now here I am.
2 things I noticed:
The front blue LED light on my NZXT Lexa case is flashing.
There are no beeps coming from the computer, with or without speakers.
Help? Suggestions?
if you got as far as the POST logo screen, chances are that the CPU is okay since you wouldn't have even gotten that far if it wasn't. Can you take a pic of how you have everything hooked up? Maybe one of us can spot something amiss.
I once had a P4 that would POST fine, but it would hang at exactly the same point every time I tried to install Windows. CPU problems aren't always black and white. I changed the CPU, nothing else, and it everything went fine.
As far as your CPU goes. If the packaging was that messed up, I'd send it back if possible.
amd uses crappy packaging for the cpus the almost alsways comes covered in that green crap that disintegrates .
some kind of bio degradable paper .
"The front blue LED light on my NZXT Lexa case is flashing"
Try this, you got a DFI board with the bug... I had the same problem so I kicked the board out.
If you have two sticks of memory yank one out. Should work then. If it does, then you can put the other stick back in in SingleChannel. DFI has yet to find a fix for this.
seeing as you have a NZXT case, it should have come with diagnostic led's on the back of the case, or on a bracket with extra USB ports that came with it. you could interpret the diagnostic led's and find the problem. That has helped me with hardware problems.
If you dont have the bracket dont bother getting it, RMA the chip. its not worth crying over used processors. especialy a $120 one. Is it still under manufacturer/distributor warranty?
With that mobo in a build I did; using a passivly cooled Gigabyte 6600gt; the tab of the card hit the north bridge chipset fan casing; and prevented the card from socketing all the way; and did something similar to waht your saying. I ended up pulled the chipset fan off and filing the fan case enough to make the card seat correctly. Voided warrenty before I knew if the board was bad however; so do at your own risk. Reset cmos and I hadnt had problems since (3200 venice @ 2.8 with 2x512 ocz gold tccd@~300 or so iir for a few months at least, i havnt touched it in a while)
Well, I do things the old-fashioned way.
Take your board out of the case, put it on a static resistant surface.
Re-DO the cpu and heatsink application.
Put your RAM in (make sure its approved RAM for the board)
Put your video card in, attach power cable if it needs one.
Place the 20/24 pin PSU cable in
Place the 4 pin aux power cable in
Attach video to monitor
Attach power button wires to header
Try it. If it posts, put it back in the case, check for appropiate standoff positon
reattach power and video cables + power switch.
Repeat POST
Now add one component at a time , POSTing each time.
Then add the windows install.
All of this assumes the bios is ok with the CPU choice.
Try swapping a different PSU into your system. I had almost he exact same problem a few weeks ago. The PC ran great for months then one day I try to turn it on and the CPU fan spins for about one second and then nothing. The lights on the mobo were on, making me think the PSU was fine. Finally swapped the PSU from a different PC into it and it ran.
I had to follow a bunch of tweaks from the DFI forums to get my lanparty nf4 working when I first got it....and I was running 2x512MB sticks of ram...I had to drop down to 1 stick and change the RAM settings manually in the bios to get windows to install....after that, it has been smooth sailing. So you might want to google the DFI forums and search through them for the sticky guide they have.
I will see if I bookmarked it on my computer when I get home from work today and if I did, I will put a link here for you to check out.
I did, however there is somewhere over 11 pages of people with the same issues on DFI street and no DFI rep has really commented on it. It deals with the dual ddr settings and one rep told me that it sometimes happens, I guess it was a bad batch or something. Anyways, I don't have it anymore, I decided to RMA it because to have to force tweak/flash a board before you can even use it is pretty pointless IMO especially when there are a ton of people in the same boat.
I recommend that you RMA that board if it comes to be the problem and purchase a board such as the MSI Diamond Plus... much better board and it's an X16 board.
