First 939 build need a little help
loopus
I just built a comp for a friend and its my first 939 install (still got some old shit myself) so swapping components to troubleshoot is proving difficult. First the specs
KN8 Ultra (non Sli)
Athlon64 3700+
2x 1gig corsair DDR400
Gigabyte 6600GT
Enermax EG565P-VE
74gig raptor
I did the install without a hitch. 2 weeks later he IM'ed me complaining of spontaneous reboots. I asked him to bring it over for me to take a look at it and by the next day it would no longer boot. It makes it thru Bios and into the SATA loading before crash. Basically right before loading the OS. I swapped the Ram and that checked out ok swapped the HD for an IDE HD with a known good install and it still crashes pre windows boot.
At this point I am just unsure and was looking for some advice. Im going to a friends tommorow to swap video, CPU and PSU to confirm those. One question I have is about how this MoBo connects to the PSU. there are 3 places for power connection. A molex at the bottom which I have connected. A 4 pin ATX 12v connection up near the CPU and a 24 pin PSU connection. I have a 8 pin cable coming from the PSU plugging into a little adapter that makes it into a 4 pin and plugged in up next to the CPU. Now the PSU's main power plug has a 20pin power and a 4pin dongle'd together that seem to fit together like voltron. However if I connect both it will not boot. I have to unplug the little 4 pin at the bottom so only the 20 pin is connected. As soon as I do that it will post fine and thats how I had it connected since day 1. At this point Im just hoping I didnt screw anything up with the power and just want to rule that out. Any help is greatly appreciated and feel free to ridicule my behind the current times knowledge :D
-loop
if you do the old mashing f8 thing while its booting does it go to the screen to allow you to boot into safe mode or no? cuz to me it sounds like a chipset driver issue, and if the other hd you put in there wasn't installed on the same mb with the nvidia nf4 chipset drivers and its trying to load another set it wouldn't work anyway, im just guessing but thats my take on it.. i was just looking at the manuel: the ATX4P1 (MOLEX) connecter is "The auxiliary 12V power connector [ATX4P1] provides an additional power source for devices added on PCI Express slots. It is highly recommended to attach 12V power from the power supplier for the best system stability." doesn't seem like its actualy required but from this it seems to indicate to me that it was ment to work with the atx12v1 connected plugged in as well. so maybie its actualy a mb issue,
I would suggest:-
1. Connect the 24 pin connection complete.
2. You shouldn't need to plug anything into an adaptor first for the ATX12v supply on that PSU?? There will probably be a p4 and a p4- connector, and these may be slotted together. It should only be the p4 connection that should be plugged in to the ATX12v supply and maybe you need to unslot both and just input the correct one. (If someone has the Enermax power supply and can give a definative answer, as I am only guessing because of how it is with my OCZ Powerstream).
3. There should be no need to connect molex to the motherboard unless you are only using a 20pin ATX PSU, and even then only if you need the extra power for your system, as far as I am aware.
I cant help too much, but I will be doing it myself for the first time in a couple days here. Any words of advice once you complete it feel free to pass it along. :)
