Firewire Pinout
NotSoSimple
I have an Abit IC7-G Max2 and it came with a backplate w/ 2 USB, a 4-Pin Firewire and a 6-Pin firewire. Well the beige cables were really ugly so I marked on the connectors (The end where it hooks into the motherboard) what colors to what pins so I wouldnt screw it up. I sleeved the cables and go to put the 6-Pin connector back on...My color reference had been whiped off! I used permanent marker also!
So I cannot find the correct pinout that I can manage to figure out so I can get this connector back in. Could someone please help?
Ok this is looking at the connector holding the cable vertical (perpendicular to your face):
Here are the colors:
[Orange] [Ground] [Pink] [White]
[Blue] [Black] [Green] [Double White] [Ground]
Hope this helps.
