Firewire/firebox help
This is my latest post in case anyone wants to skip the beginning:
Well this is depressing :(
I bought the card. Installed it into a PCI-E slot. did the drivers and everything. But after I plugged my firebox in, the computer didn't recognize it. There was no 'sound effect' or any recognition pop up. The weird thing is that the front of my case has a firewire input and the computer detects that (and gives me the 'this usb port not recognized' error) but I'm assuming that is irrelevant b/c I'm assuming the firewire card only adds firewire capabilities to, well, the card output (in the back). Besides, I used to get the same error even before my firewire card was installed, so it probably means nothing , maybe the computer is just confused =/
I took some pictures showing my card installed on my mobo, and the way it looks from the back of the computer with my firebox firewire cable plugged in. I have no idea what's going on, help would be super greatly appreciated, thanks hardforum
http://img.photobucket.com/albums/v7...128_222304.jpg
http://img.photobucket.com/albums/v7...128_222311.jpg
http://img.photobucket.com/albums/v7...128_222145.jpg
http://img.photobucket.com/albums/v7...128_222317.jpg
Did you plug in the firewire front panel cable to the pci-e card you bought?
From the sound of things, you have the front panel firewire plugged into a motherboard usb header
Yeah, for sure the firewire front port isn't connected to the mobo 'effectively'. I think it's because my motherboard doesn't support firewire. That's why I bought the internal firewire card. So far I've been trying to connect directly into the card's firewire port, with no response.
:confused:
My friend came over the other day and thankfully found the problem. Thanks for the help anyways Hardforum
In case anyone was curious about the fix:
The drivers were incorrectly setup. It defaulted into using a driver that was neither the TI driver or the Legacy driver, both of which would've worked. Once that was changed the box was recognized; from that point is was just installing the Firebox drivers. :)
