the new firefox precaches almost as aggresivly as vista.
It predicts what links your going to click on and then starts loading the page.
+ faster load times
- much much MUCH more memory used.
if you leave the same thing running for a few days without touching it on a website with a big database I've seen firefox take up as much as 700mb
*snip*
Also you should change your Task Manager to show more relevant info to look like this:
The basic default info is relatively useless because although a program can be using <x> amount of actual physical RAM (as your pic shows), what's going on behind the scenes is what really matters the most and the VM usage can spike ridiculously high - if that happens, your pagefile gets slammed more often and system performance suffers. Also, XP has a "handle limit" of about 10,000 handles for most purposes. If that number jumps up over 10K because some program is coded poorly, you get that dreaded slowdown of the entire system as it chokes and bogs down - yet Task Manager will say you have RAM and nothing is using CPU time. It's the number of handles choking the system, and there's a way to increase it over the defaults also.
Hope this helps, somewhat...
Unless FF has telepathic powers I really don't see how that is possible and don't believe it either. Or is your post missing a winky?
