TechStuey05
- Aug 5, 2005
Hi, for about 2 weeks when I go on my computer in the morning firefox is frozen. I dont close firefox at night instead I minimize it. In the morning when I try to maximize it I cant, once in a while it'll maximize but it'll be completely frozen. I haveto hit ctrl alt del to manually close it. When I open up firefox it works great for the entire day. Just in the morning this happens. I think that I've been infected with some kind of malware. I uninstalled and reinstalled firefox, deleted and created a new profile, and deleted the installation folder. Same problem, soo I performed a sytem format (not sure if it was a destructive format). no problem for about a day but after that the problem came back. The strange thing is that I've had this computer for about a year with zero problems. I've never added any memory, never upgraded or touched the video card or anything in the computer. The computer is a sony vaio pcv-rz36g, 3.6 ghz, I backup all my stuff on an external hardrive, and the mouse is a Logitech G7, not sure if this info matters though. You see about 2 months ago I went to a bad site to test out google's phishing filter (didn't realize at the time that there was a way to test it in the toolbar), Anyway I started having strange problems with my computer like when I added a file to my computer it asked if I wanted to replace the file, that's normal but then the mouse would automatically go onto the yes option. I found a way to fix that problem but the antivirus would be disabled when I restart my computer then it would re enable. I scanned using spybot, adaware, ewido, trojan hunter, you name it, but it found nothing. Another problem was that when I used trend micro house called about a minute into scanning it would automatically close soo I couldn't complete a full scan. Anyways I got fed up with these problems so I brought it into comp usa and they performed a destructive sytem format. Since then the problem never came back but now I have this problem, not sure if they're part of the same problem. Mabey a hackers been dropping malware on my computer. My antivirus that I use is Avast, my firewall is sygate pluse I have a Lynksys router as my hardware firewall. I immunized my computer using spybot, and spywareblast. I'm extremely fustrated with what's happening with Firerox. I'm even willing to perform another destructive system format. 2 days ago I installed process guard a program that helps protect your computer and applications from trojans and malware. Yesterday when I went on my computer in the morning I found that my computer had restarted by itself. Same thing happend today so I uninstalled process guard. Now I have spybot tea timer enabled. oh btw my version of firefox is 1.5.04. Any help is greatly appreciated! Stu
