Firefox Developer Edition 38
HardOCP News
[H] News
A 64-bit build of Firefox Developer Edition is now available for Windows. Thanks to cageymaru for the heads up!
A 64-bit build is a major step toward giving users rich, desktop-quality app experiences in the browser. Let’s also take a look at some of the other features that make this a release worth noting. If you haven’t downloaded the Developer Edition browser yet, it’s a fine time to give it a try.
still a ram hog right?
I only had 5 tabs open, and it takes 1.3GB of ram and won't let it go
Seriously adjust your cache settings, I have over 80 tabs open and I'm only using about 1GB of ram. Also if you are using an old profile create a new one.
Any reason to use that developer edition over Waterfox ?
Waterfox update support disappeared for a long time and in the midst of a few browser exploits too. But yeah, they're stealing its thunder. But Firefox has other problems.
You can't possibly be working with all 80 tabs?! If you are, you're a hell of a multitasker.
64 bit browsing is still way off in the future until dev's start writing 64 bit plug in's at the same rate as x86 plug ins.
If you use firefox with tabmix plus and group like tabs to together it's easy. My tabs groups the the following: tech sites, gaming(wot mostly), current project research, ebay auction, home/car repair, and newegg/amazon. Having that many tabs keeps the creative juices flowing and I use the scroll wheel to switch between them making it easy to get rid of tabs I don't use anymore. There's a groups your tabs button that allows to stack even more tabs, I have a group related to Wikipedia that has tabs on books telling me how many books per series their names and what order to read them and that's an additional 18 or so tabs, but I don't check that group very often.
I find it funny people complain about the memory usage of Firefox when chrome hogs the cpu for no reason. Ram is cheap and your computer uses the same amount of power regardless of how much ram is being used, cpu usage though eats more power.
I can already tell that the 64-bit version runs so much smoother and efficient than the 32-bit version.
