Firefox 4 Beta 8 is Out
HardOCP News
[H] News
All you alternative browser users out there that want to get in on a little "beta" action, should head on over to Mozilla and download the new Firefox 4 Beta 8.
The latest beta version of Firefox is now available as a preview release. Take it for a test drive and let us know what you think! This is pre-release software: you may encounter compatibility problems with some websites and add-ons. If you find a problem please let us know or file a bug.
Ditto. I like the flexible interface, but with almost none of my add-ons working, I never use any of these betas for more than 5 minutes.
The FF 4 betas have all crashed on me within five min anyway...
With Amazon's website no longer displaying properly in FF, I think FF's time is almost up for me...
the biggest deal for me is, they haven't fixed the text rendering problem. it is very difficult to use it, when everything looks like it's in comic sans.
With Firefox (3.6) I just set all of my fonts to Arial and use an add-on called "NoSquint" that keeps my zoom at 125%. That's ideal for browsing on my 1080p TV without dealing with tiny fonts or increased font sizes causing pages to align incorrectly.
I've been pretty happy with the new IE for the most part, too...although a few media plug ins don't work well and keep me from using it full-time.
I just know that for my own personal use I *have* to have a good bookmarks menu and the ability to zoom...and Chome has failed me on both fronts.
Use the portable version, which you can get from www.portableapps.com - it will be a totally clean install, that runs from it's own folder, will not touch your current Firefox installation at all (just don't try to have both running at the same time, that creates a conflict because of what's in RAM), and do some testing or just plain old looking around.
They've gotten rid of the status bar nowadays; when you hover on a link it'll show up in the URL bar, not sure I like that, but then again there's a lot of things that I don't particular like about the redesign. Sooner or later I'll be forced into it but for now, 3.6.13 works absolutely perfectly for my purposes and considering how massively I've tweaked it over the past year (meaning the install which has been upgraded through each successive update).
If you must try your addons on the portable version, make sure to install the Nightly Tester Tools which can force non-compatible addons to actually work - they could break the whole thing, however. Cool thing about the portable version is it takes under a minute to create a brand new completely clean one - just run the installer again and create a new folder. Voila! Fresh install in seconds for more testing or screwing around.
