Finishing an i7 build
Kirbstomp
Heavy gaming would be the primary function of the build, with a decent amount of multitasking as the secondary concern (Mathematica, maybe some CAD apps I might have to use for school).
I do not have a set budget, although I am anticipating spending $1000-$1500 potentially on this build. Whatever parts I choose need to represent good bang for their buck.
3) Where do you live?
Boulder, CO (Have access to Denver Microcenter)
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU - Will pick up an i7 920 Friday at MC via in-store deal.
DVD - Picking up a SH-S223F from MC along with the i7.
Case - I would like a new one (will look at a few in-store at MC,) but I have the option of re-using my CM ATCS 201 as well.
Thermal Paste - Have some AS Ceramique I could possibly re-use.
CPU Cooler
RAM
MB
Video Card
HDD
PSU - One of my friends has a lightly used 750TX he is going to sell me.
Case - Again, I could re-use my CM ATCS 201 if I wanted.
Keyboard - Saitek Eclipse II (just bought a month ago)
Mouse - MX 518 w/Ratpadz XT, both are still in outstanding shape, I have plenty of spare teflon mouse feet pads too.
Headphones - ATH A700s
Sound Card? - This seems tricky as I have an Audigy 2 ZS Gamer legacy PCI that I am curious about whether or not it is worth re-using either in combination with or in place of onboard sound.
Thermal Paste - I do have some AS Ceramique sitting around, but it is several years old, is it worth re-using or should I be safe (maybe there's separation?) and purchase something like AC MX-2?
6) Will you be overclocking?
Absolutely
Acer H233H - 1920x1080
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Nothing fancy, a single card should be adequate for my 23" monitor. Upgrade room could not hurt though if it is only a few dollars more, but I would rather go for the best value board for stability/preformance.
10) Do you already have a legit and reusable/transferable OS key/license?
I have two XP Pro 32-bit copies and to my understanding the key will work with the 64 bit as well. The other option would be downloading Windows 7 RC and installing that. My thoughts are that I am probably betting off just going with Windows 7 RC.
Recently I asked for some help with upgrade advice for my older socket 478 system, but the upgrades ended up taking a lot more time and effort than they were worth, and I am not very satisfied with the results. Fact is, my single core processor just is not cutting it. There seems to be some great deals lately on parts, and consequently I have decided to upgrade all together.
I have the system pretty well planned out expect for a few key pieces that I need some help with.
Thermal Paste - Probably buying some AC MX-2 to be safe rather than use the several year old AS Ceramique $7.99.
CPU Cooler - Xigmatek DarkKnight $39.99
HDD - My old drives are IDE, time to upgrade to WD Caviar Black 640 as main drive $74.99 and WD Caviar Black 1 TB as storage $99.99.
RAM - I've narrowed it down to 4 good choices here, and am leaning towards the Mushkin because I have had outstanding results with them in the past and also offer a lifetime warranty even though Newegg does not state it. Although, pairing either of those OCZ modules or the G.Skill with the Asus P6T gets me a $20-$22 discount.
MB - Here is probably where I need the most help in terms of choosing a board for performance and stability. I plan to over-clock as much as possible on air and I would also like something that would be good for a few years down the road. After reading a few reviews, the Asus P6T seems like a stable board for $250 and would offer a good over-clock. Can either order off Newegg for the combo or purchase from MC.
Video Card - Again, an area where I need some help. I would gaming on an Acer H233H @ 1920x1080. I was thinking a 4890, but keeping bang for buck in mind, this BFG GTX260 seems like a steal after it's $20 MIR for $149.99.
One last thing I should note is that I have a Newegg coupon good for 10% off my order up to $400 total (i.e. a max of $40 off).
Thanks for taking the time to read this and possibly helping me out.
Gigabyte Radeon HD 4890 1gig + Gigabyte GA-EX58-UD4P for $465 ($20 MIR on video card, $20 MIR on mobo)
+1. Good motherboard and good video card. Nice combo.
For the RAM, get this 6GB G.Skill DDR3 1600 kit.
For the hard drive, go with the Western Digital 640GB Caviar Black.
You've selected a good CPU cooler in the Xigmatek Dark Knight.
I recommend the Arctic Cooling MX-2 as the thermal compound.
Corsair 750TX is an excellent PSU. Good choice.
Case is your personal choice.
Get this Video/Mobo combo man.
All that combined savings makes for a nice deal on both. Did some more research on my own as well and the UD4P seems to be a very favorable board for the i7.
As far as the RAM goes, I think I'd like to gamble on the Mushkin since the specs are identical to the G.Skill and I can also get the rebate.
Hopefully when I go to MC on Friday I can get a D0 (they just got a shipment) and I can finally decide on whether or not to keep my current case or upgrade to a newer one with more features.
That aside, my only question at this point (although it does not affect my purchases), is should I put my Audigy 2 ZS Gamer into the new rig or just go with the onboard sound of the UD4P?
Thanks for the help so far.
