I finish building my rig today ! (specs below)
But when I built , i check my cpu temp and it was 50-53 C IDE!!
Is that normal? I have a SP94 and a Vantec Stealth. I plug the Power to the CPU fan spot on my Motherboard. Does it automatically Adjust my RPM for the Vantec?
Maybe I could put the fan indirectly?
I did switch them but I couldnt tell the difference if it was on backward or not....
can you guys tell me if the difference between backward or not on the fan without feelin the air...
I hope the motherboard auto adjust my fan... I dont know... help me
