Finicky Motherboard
Seijuurou
I recently purchased the Asus Striker Extreme to go with a Q6600 and I've had quite the night. After 8 hours of struggling with my case to get everything in i finally boot it up to get the dreaded CPU INIT error. After an hour and a half of trying everything that I researched I got it to post. Right after that fiasco I boot it up and get a CHECK RAM error. I tried absolutely every DIMM with all 4 sticks of my RAM that was on Asus' approved list. I finally decide to call up ASUS to sit on hold for 40 min. to my surprise get somebody who knew what he was talking about. He told me to take the mobo out of the case and try booting it that way. I'll be damned if I can't get into the BIOS now. My question to you all is why would a badly grounded mobo give a CHECK RAM error instead of sticking to the CPU INIT error?
If it was shorting out, who knows when or where it was shorting out. It may have been shorting at multiple spots at different times.
The Striker Extreme is a pain in the ass. I should know. :cool:
Apparently that didn't fix it because i kept getting the TEST RAM error. I finally made it into the BIOS and found out that my RAM runs at 2.2v which the Striker Extreme hates. Should I set it at 1.85v to make it happy? By doing so will I damage anything?
well i think most ram (ddr2) can handle 2.2 for everyday usage. if you want to keep your rams warrenty (if you have one) set it factory voltage.
also i have an asus commando that is a pos that gives me a million errors about dram and shit. I hate this board so much. lets put it this way not looking like my next mb is an asus.
After another 3 hours of troubleshooting I have no clue how it fixed itself. I set the RAM to 2.2v because I found out that my mobo was actually undervolting the RAM. It then went right back to the TEST MEM error. I then just wanted to throw the mobo out the window and run it over. Instead I decided to take out the CMOS battery and reset it. Still no avail. I then tried it without the CMOS battery. Post as well as gets me into the BIOS... I change the jumpers again and I'll be damned if it didn't work. I guess I angered the computer gods because they were certainly out to get me today.
