i3lacKnyte
- Jun 1, 2003
hey guys, just a quick question. i just built my new athlon64 rig inside a lian li pc65b and the end result is that it is littered with fingerprints. i was just wondering what is safe to use on cleaning the anondized aluminum that wont be too abrasive scratching the metal or the paint job? will a paper towel and windex do the trick? i lost the manual so im not sure if there was a cleaning section in there (just because i lost the manual doesnt mean i downloaded my case off the internet illegally!)
on a side not, after working inside computers for proabbly the last ten years of my life, this is the most comfortable case i have ever worked inside of. if your someone who is constantly ripping apart your machine for some reason, this is the case for you.
