Fine temperatures for i7 3770
carlmart
I have recently finished the setup for my new computer:
Gigabyte GA-Z77M-D3H mobo
Intel i7 3770 cpu, with Corsair A50 cooler
Corsair 8Gb Vengeance memory
Today I also installed Aida Extreme and my cpu temperatures seem to be around 43C for the package and 40 for the cores.
Are those temps fine?
I also run a stress test with Aida, and temps reached 60C.
AFAIK the cooler is properly installed, or things might have gone hotter on the tests.
It's important to note that I live in Rio de Janeiro, and this week temps have gone quite high, topping more than 41 degrees.
I do not overclock anything or intend to. The case is an Antec P180, for now working without the side door, and the air feels cool on the other side of the cooler.
Anything I should do or could do to cool things further, not being water-cooling that I do not want?
Space is limited for a larger cooler, as it already almost touches the memory plate.
what is the temp when running prime 95? I assuming that the above is not under load...
Stress test in AIDA64 should be just about as demanding as Prime95 computationally. Unfortunately AIDA provides little documentation as to what their "Stress Test" actually is.
Just googled it, and apparently the diode PCH temp is the chipset temp.
What I also wonder is what the right temp for that is. Right now it's at 56C, hot to the touch but not something you can't keep your finger on. It would be nice to lower it a bit, but this case does not provide space for any side door coolers.
