finding the right removable drive system
gopherscanswim
I'm looking to add a removable storage system to my new computer.
I want/need
  1. aluminum
  2. keyless would be ideal (but still with a power switch)
  3. fanless, or with a fan that turns off with a front power switch/key lock and is of course off when the drive is removed (it seems some don't do this, stupid!)
  4. SATA
  5. single drive units, not 3-in-2 or 4-in-3 type units. I'll probably be buying two of them as well so if they don't cost a lot that's a bonus
I've spent the past couple days searching all over and looking at newegg and other sites I use frequently and it seems the manufacturers aren't all keen on providing reliable information and the user reviews are spotty as usual. I'd rather get some good feedback before I start throwing money every which way.
Would these be for mounting drives inside the chassis or outside? That is, do you want things that go in 5.25" bays or outside with power bricks and eSata?
