Finding files by Ownership.
bigstusexy
I'm asking for help but a quick rant. I find it really odd and weird that I can think of ways to classify files but whenever I look at windows search its never an option to find the files or object.
Anyone know a good way to find files by ownership? I have a user I had to impose a quota on and they were over their limit when I put it because their gross overuse of space. Now I'd like to point to the files exactly as the quota management console lists them however I don't quite know where they are. I can't search by owner ship, but I can search and then sort by owner, only problem is the file list is so huge the search window seems to just kill it self. This is a win2003 member server.
If you have R2 you should look at the storage management reporting tools.
There is an app called, Directory Report. It isn't free.
Another options is write a batch file that scans the entire drive and write another batch that pipes out to the data log based on the username.
Thanks for your input, I never thought to do that requiemnoise! I did get lucky though, I found that I was searching the entire drive in case the security was ever lapse and they coudl write to almost anything but as it seems they only have two areas, I searched the other one and found most of the files there. Now if only this person would use their 30 computer lat with 80GB per unit or perhaps the 1TB drive we bought them and get their crap off the network! *cough* now that they know where the rest of it is.
