Originally posted by mattsmall
so a 9500pro at 425core and 630mem would have 10.080 gb sec? isnt that what it has stock
Originally posted by pxc
...unless you want to measure GB/s as 1024^3 bytes/s= 1 GB/s.I wouldn't get too picky with bandwidth as I do with memory/storage sizes. I personally like the larger number for bandwidth figures.
But say you had a 128MB video card and you consider reading the whole memory space 8 times in 1 second as 1GB/s of bandwidth (8 x 128MB = 1GB). So in your test, do you stop when you reach 1,000,000,000 bytes read and leave the other 73,741,824 bytes in the GB unread (around 7% remaining, a little less than 1/2 of the last of 8 128MB reads)? So 10.08 billion bytes/s of bandwidth really equals only 9.39GB/s.
Or if you've been brainwashed by hard drive manufacturers that 1GB = 1 billion bytes as their disclaimers state with little *'s, I guess there's no point arguing. If that were true, why do they need an explicit disclaimer?
Please, no one start with GiB... no one uses that.
Originally posted by Brent
the speed of the memory (DDR) times 32 if its a 256bit bus or 16 if its a 128bit bus
for example a 9800XT's memory speed is 730MHz so times 32 = 23.3GB/sec
Originally posted by EarthwormJim
You're correct in finding the theoretical bandiwidth, but your leaving out a step as to how this is found. You're doing 32 for 256bit, and 16 for 128bit, this is correct in a way, but the actual way of finding bandwidth is this: Speed multiplied by the bus width devided by 8 (it's devided by 8 because there's 8 bits in one byte, and typically bandwidth is in bytes).
So bandwidth of 9800xt: 730mhz X 256bits/8 = 23.3GB/s. Same answer as Brent, just without the missing step.
ha my 9500pro has more bandwidth then a stock 9700prowoot
9500pro has a 128bit mem bus, as opposed to 9700's 256.Originally posted by mattsmall
finding bandwidth?
