Find hardware specs after format
vroom_skies
Hey all,
Just wanted to know what software you use after a fresh install of windows to view the hardware specs. I have this laptop that has a fresh format, yet no drivers installed. I'd rather not open it up to find out what drivers I'd be needing.
The laptop is a Toshiba M45, and I have the driver page, there are just a few driver options for different configurations. So I need a piece of software that can tell what the exact hardware I have.
Thanks
Wouldn't it be faster if you go to the support page for that laptop and download the drivers from there?
I use Everest Ultimate Edition when I do these kind of jobs then go to the manufacture for drivers (Realtek, Intel Pro/wireless, Nvidia, Ati....etc)
Best suggestion: hit Windows Update first, or as soon as you can get online with a wired or wireless NIC - Windows 7 (and Vista) should cover pretty much every wired or (popular) wireless NICs out there. Once that's done, Windows Update should have drivers for pretty much everything.
If you do encounter a situation where you can't locate a driver, you can pull up the device info in Device Manager, click the Details tab, look at the Hardware IDs info, get the VEN and DEV ID codes (each are 4 digits), and then punch those 4-digit codes into the appropriate boxes at:
http://www.pcidatabase.com
and you'll get some info to work with.
PCWizard, AIDA64 (was Everest, recently re-acquired and renamed back to AIDA64), Sandra, and several other products can all give you appropriate info on the hardware in the machine as well.
