finally upgrade time, assistance please!
horrorshow
Lakewood Original
well, its finally that time again!
i'm going to keep my current comp as the server/lan machine so there will be NO transferred parts.
to put it bluntly, i'm a light gaming, web browsing, media whore....
anyways, here are the specs i compiled off newegg:
Intel Core 2 Duo E6750 Conroe 2.66GHz LGA 775 65W Dual-Core Processor Model BX80557E6750 - Retail - $189.99
ZEROtherm Nirvana NV120 120mm 2-ball UFO Bearing / Transparent CPU Cooler - Retail - $45.99
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX All Solid Capacitor Intel Motherboard - Retail - $79.99
G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ - Retail - $89.99
Western Digital Caviar SE16 WD3200AAKS 320GB 7200 RPM SATA-300 Hard Drive - OEM (x2) - $149.99
EVGA 512-P3-N802-AR GeForce 8800GT Superclocked 512MB 256-bit GDDR3 PCI Express 2.0 HDCP Ready SLI Supported Video Card - Retail - $259.99
Antec Sonata III 500 Black 0.8mm cold rolled steel ATX Mid Tower Computer Case 500W Power Supply - Retail
ASUS 20X DVD±R DVD Burner with LightScribe Black SATA Model DRW-2014L1T - Retail - $38.99
SAMSUNG 226BW Black 22" 2 ms (GTG) DVI Widescreen LCD Monitor - Retail - $319.99
=TOTAL= $1,284.86
solid? all advise is appreciated.
THANKS.
The rig looks solid as a whole, but consider getting some of the parts from stores other than NewEgg. ZipZoomFly, ClubIT, eWiz, and Mwave are a few of the places to consider. The benefits from shopping around (just two or three places, as compared to just NewEgg) come from lower prices, various rebates, and/or free shipping.
Additionally, Microcenter has a deal on the E8400 -- the replacement to the E6750 -- for $200. See if you could jump on that deal first.
looks pretty good i'd look into getting a bigger case, maybe the bigger antecs or the coolermaster cm 690, i just built a comp. with this case and was impressed, also i think its on sale go look in hot deals. the evga 8800gts 512 is the same price after rebate at newegg.
Looks soild. However, if you're a light gamer, you can get a cheaper video card and it will be more than enough for your needs. That superclocked 8800GT for $260, although a great card, you can get a standard clock version for less than that. The MSI 8800GT is at $200 after rebates. Also, 9600GT for $180 at most places should be more than enough for you if you're a light gamer.
great idea it has and will in the future save me $
