Finally pulled the trigger
skittles15
For those interested
ASUS P5K PRO LGA 775 Intel P35 ATX Intel Motherboard - Retail
Intel Core 2 Quad Q9300 Yorkfield 2.5GHz LGA 775 95W Quad-Core Processor Model BX80580Q9300 - Retail
Western Digital Raptor WD360ADFD 36GB 10000 RPM SATA 1.5Gb/s Hard Drive - OEM
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPK - Retail
SAMSUNG Spinpoint F1 HD753LJ 750GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Sony NEC Optiarc 20X DVD±R Burner Black SATA Model AD-7200S-0B - OEM
EVGA 256-P2-N761-AR GeForce 8600 GTS 256MB 128-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card - Retail
depending on what he gave for it it may have been a good deal.
Otherwise he either doesn't need anything powerful and found that adequate or... well... Iunno.
3dsmax...no real gaming besides a little bit of CS. That card i snagged for 80 bucks, can't go wrong.
I would have gone with the 74GB Raptor and the 8800GT 512MB personally. Otherwise not too bad.
I would have gone for a WD6400AAKS, which transfers files faster than my WD1500ADFD (raptor). Not a bad build, though. Thanks for the pic! :D
I haven't done any research on that but I find that hard to believe.
Raptors own synthetic benchmarks, but my experience with a 74gb Raptor was that it was expensive and hard to tell apart in terms of actual performance from my Seagate drives. Meh.
The Raptor finds the files faster, which doesnt do much for overall performance, apparently. My KS loads windows faster, and can transfer a single 4.7GB file faster -- to and from my RAID0 array. If its a bunch of files, the performance difference is less noticeable.
Synthetic? I got synthetic... but I was making my statement based off of my personal experiences with both drives...
Those were posted in the HDTune score thread, too. So if you're interested in others: http://www.hardforum.com/showthread.php?t=1284410
I thought we were talking about the 150GB model? I know the 74GB drive is long in the tooth at this point and its' behind the curve compared to newer conventional SATA drives.
