Finally overclocking my 2600k - where to begin?!
jnick
I haven't overclocked a machine since my E6600. I remember the days of raising the FAB and dealing with memory timings. I feel completely lost in the overclocking world now.
I have an ASUS P8P67 pro and a 2600k. Where do I begin? Are there any good guides out that I can read? Besides raising the multi and voltage, what do I need to turn off? Speedstep? C states? Any tips to help me get this puppy off the ground would be awesome!
Thanks!!
Don't mess with any of those settings, just change the multi to something low like 42 to start and then watch your temps and such. If things are going well and staying cool while benchmarking, then increase the multi some more. I would honestly leave everything else at optimized default settings.
Official ASUS p8p67 Series Overclocking Guide. That its the Bible of p8p67 Information. what do yo need to turn off? nothing. you can easily overclock with all C States Enabled and Speed sted. the only thing you have to know its how much do you want to overclock that monster.. knowing that you will know if you need to change another Parameter in Bios like LLC, PLL overvoltage, Etc.. however in the guide its all explained seriously well..
what cooler are you planing to use for overclock?.
Thanks for the info peeps. Running an H100. What are the programs to use to stress test and monitor temps these days?
actually people keep using Prime95 and (IBT)IntelBurn Test wich use linpack to stress chips. i like to use both, and also use OCCT and Aida64.. and well of course the real stability test: Daily gaming... dont close in a single program, run P95 then IBT then a couple of test with Aida64 and then gaming. if you test with all of those programs and no crash no issues, you can say you are stable, the 2600K its the king of stability, so no hard to keep it fine.
So I started tweaking yesterday and here are the results thus far.
1hr of Prime95 @ 4.2Ghz (all I changed was the multi to 42 per core)
1hr of Prime95 @ 4.4Ghz
I re-started Prime95 when I went to bed last night and it's still running with the settings above. By time I get home from work tonight will be roughly 24 hours. I also did do a quick 15 minute gaming session in BF3 with those settings without issues.
What would be the next step? Raise it to 45 and test again? At what point should I be concerned about my temps? Do I continue to leave the voltage on auto? I know its needed for speedstep but I'm sure I'll need to manually set the max voltage at some point, no?
Thanks!
[EDIT - Sorry the images are so big. Getting used to this imgur stuff! Used to use photobucket back in the day but their site is crap now :( ]
Your motherboard is giving you way too much voltage. Try going to 4.2 and 1.225 vcore, check for stability in prime95, aida64. If you are set on 4.4 try the same vcore as above, if it crashes bump it up .005. Keep doing this until it is stable for 30 mins in prime95 (watch temps). Now go play some games where the CPU will ramp to different loads, test stability.
For testing stability purposes I would disable c3,c6 states in your BIOS.
The voltage its perfectly fine... 4.4ghz at 1.304v its good specially for autovoltage with those max temp of 68C... Also its not necesary disable the C states. That was a stability issue in first gen "core i" and older.. From sandy bridge and later C states aren't any kind of issues... But voltage its fine.. Some people have to use 1.35V for 4.5ghz. And 1.4 for 4.8ghz more or less and thats fixed voltage.. Autovoltage at 1.304v i have to say again its good..
Thanks! How do I go about changing the voltage? Doesn't it still automatically regulate the voltage when speed step kicks in to lower speeds? For example, when it downclocks to 1.6Ghz, it doesnt stay at 1.225 vcore, does it?
This is correct. 1.3v is just fine for a Sandy. If you can keep it below 1.4v and do 4.4-4.6Ghz your doing just fine and the temps should be in the upper 60s or even low 70s when under full load. If you want to try for 4.8, you'll probably have to bump it to 1.4v+ or more, but it is doable, although I would recommend trying to keep it under 1.4v for 24/7 operation.
Is it better to run a 'fixed' vcore or leave it auto?
Auto if its possible and keep using those excelent amounts of voltage... Thats mean.. The CPU will only work at full voltage while high loads, during normal operation it will range from the idle (and soft loads) 0.978v all the range up to 1.304v. So at a regular app that do not require de full potential the chip will run safe and cooler with less voltage in use... Fixed voltage are for voltage hungry chips that present unstability with autovoltage or that draw ton of voltage in auto or the motherboar deliver ton of voltage without be needed...
Other people use negative offset voltage to undervolt under loads to compensate the high delivered voltages and still keep it cold and with lower voltage under loads.. My first 2600K was really power hungry it required a good amount of voltage to be fully stable, then my second 2600K that was kind of like you that was a golden chip at 5.2ghz with 1.44v.
So in order your chip keep those load voltage keep it that way.. Fixed voltage keep the chip all the time even at idle with full voltage wich its not good to the lifetime of the chip..
My honest opinion would be to leave it auto as your temps are fine. As far as the next steps, with mine, I found I could do 4.8 no problem, but the temps would get into the high 80's and I didn't like that at all. So I just keep it at 4.5 and it stays nice and cool, low 70's, and I honestly couldn't tell any performance difference between 4.5 and 4.8 except in benchmarks really. Its basically up to you how much you push it and for how long.
agreed, the reality its 4.5GHZ its the sweet spot for sandys.. it perform at a really nice temp, specially OPs max 68C under prime, so during normal gaming and normal usage it should state much lower...
I have some related questions that I figured I'd put here rather than start a new thread.
I have a 2500k that has been at 4.1ghz for a long time as I didn't adjust any settings when 4.2ghz proved to be a bit unstable. I'm now trying to get more out of it but I'm a bit confused about voltages. In BIOS I set the Vcore to 1.38v, and when I check the voltage in CPU-Z it indeed shows 1.38v. However, when I start Prime95, CPU-Z shows the voltage at either 1.296v or 1.284v. What's going on? Why does it seem to be at a lower voltage when at 100% use?
I was hoping to hit 4.5 but even 4.4 isn't proving completely stable at 1.38v (blue screened after an hour of Prime95). It seems that I still have a bit of headroom as my temps topped out at 61 during that hour, but I was really hoping to stay away from 1.4v. Here are the rest of my settings fyi:
QPI/VTT: 1.12v
System agent voltage: 1.135v
CPU PLL: 1.9v
What are your temps at load at 4.3 and 4.4? Is your cooler keeping up with the increase. About the load question, I'm not 100% sure, but I think that is called Vdroop or there is a setting in my bios for Vdroop, which would adjust the voltage dropping, (I think, not an expert here).
edit: apologies, you did post your temp, and this flu is killing my brain and affecting my reading comprehension.
You're right, on one of the guides I found says "Load-Line Calibration: As the CPU accepts more work, its power draw increases. This in turn causes a voltage drop (vdrop), which is automatically compensated by the motherboard by increasing the applied voltage slightly."
Am I correct in thinking that I should be trying to reduce my Vcore below 1.38v but increasing one of the other voltages to keep the voltage at 1.31 or 1.32 when at 100%? If so, which setting should I be adjusting? Is it ideal/possible to have the voltage be more or less the same at both idle and at 100% load?
Drop the PLL voltage to 1.78, set LLC (load line calibration) to high or very high if still have voltage drop. 1.38v its insane high for a 2500k at 4.1GHZ. that speed should be reached kinda easy at stock voltage or near stock voltage. so if i were you i would load stock settings (load optimal settings option) and would start again without mess with any option, just increasing the CPU multi, and watching what voltage are automatic requiring, im 100% sure that at 4.1-4.2ghz you can even set a negative offset to undervolt your chip. i had do that tons of time without any issue on friends machines and on my oldie 2600K. in fact my actual 2600 its at 4.2 undervolted, so i would start all the process.. just my 2c..
Thanks, I may not have made my history with this chip clear. It was at 4.1 on stock voltage for a long time (4.2 at stock wasn't stable). I have recently started trying to get up to 4.5 if possible. At 4.4 it couldn't handle more than 10 seconds of Prime95 until I got up to 1.38v... I then increased the other three voltages (one by one) to the numbers I mentioned to try to stabilize it at 4.4 but it still blue-screened after about an hour of Prime95. I'm fairly certain my MB/BIOS doesn't have a basic LLC setting where I can pick high, very high, etc. I'll clarify tonight when I'm home.
If not hace a normal, high, very high etc.. It should be, 1, 2, 3, 4, 5.. Some motherboards have the 5 as the higher one others as 1 as the higher, it should say it in the leyend. Generally are 0%, 25%, 50%, 75%, 100%.
This is Spurs - wasn't able to log in under this account until I was on a computer that had the password remembered. Here are my options in BIOS - as you can see, no LLC option
Suggestions appreciated.
