Italiano86
- May 26, 2008
So I finally ordered my watercooling parts to go into my 800d and am just hoping I got everything set straight.
My Stuff:
Bitspower v2 top
2X Bitspower white led plugs for Res
Swiftech 655 with speed adjust
16 ft. of PrimoFlex Pro LRT White Tubing - 7/16in. ID X 5/8in. OD
Bitspower Matt Black G 1/4 - 90 Degree Dual Rotary
Bitspower Matt Black Rotary 90 degree G 1/4 adapter
10 x Bitspower G1/4" Matte Black Compression Fitting
Bitspower Quad Rad Guard
XSPC LCD Temperature sensor - white
Bitspower Matt Black G 1/4 Temperature Sensor
Bitspower Matt Black Rotary 45 degree G 1/4 adapter
[URL="http://www.jab-tech.com/YATE-LOON-120mm-Case-Fan-D12SM-12-Medium-Speed-pr-3770.html"]4 x YATE LOON 120mm Case Fan - D12SM-12 - Medium Speed[/URL]
4 x YATE LOON 120mm Case Fan - D12SL-12 - Low Speed
EK Supreme HF block
XSPC RX 480 rev.2
EK Advanced 250 res x2
EK 470 Block
PT Nuke but not sure If I should have bought this one instead
Bitspower D5 / MCP655 Mod
Black 6/32 screws for rad
All in all I spent about 840 on everything including shipping. Thankfully I didn't have to pay tax, I would have been mad to since it would have been another 80, lol. Hard to believe it cost me this much, but I did get a little extra bling.
Let me know what you guys think. I will probably make a little build log once everything comes in and to show my setup. I'm just hoping I got the right stuff. It will currently be in my q6600 build which is oc'd @ 3.2, but I will definitely raise the clock with water, and I will also oc the hell out of my 470. Eventually, I will probably add an i7, but that's probably going to be next year if I even need it.
My Stuff:
Bitspower v2 top
EK Supreme HF block
XSPC RX 480 rev.2
EK 470 Block
