finally.. my own search engine.
Status
Not open for further replies.
EmpathY
whats up guys, ive been wanting to always have my own search engine.. now that has came true, and ive been working on it for a while. all your search results come from google, and its the same thing. if you could, use www.ispyinfo.com for your searching needs, it would be greatly apperciated. soon I will start to offer free email/domain web hosting/and other ammenities. its nothing out of this world, but like they say everything counts.
Thanks in advance,
Andrew
um no i am not going to use your search engine. all you are doing is passing along the search string to google. It looks like you spent alot of hard work on this "search engine" of yours. :rolleyes:
Code:
<FORM method=GET action='http://www.google.com/custom'>
Lollerberries. Excuse me while I use google instead of your form which redirects to google.
All you're doing is an HTTP get on google, and removing the header.... :rolleyes:
I don't understand ... this is just a Google shell? Not trying to be mean, but what's the point? You're not making any money from targeted search results, so what's the goal here? You should build your own search engine like Yoomy.com and make your own money, not rip off Google.
Well, it's not just Google with a different layout. It returns less than half the results of Google, usually.
That doesn't really change the points made above, though. Unless you can iterate specific optimizations or the like, we'll just assume it's the same sort of "search Google" box that Google freely provides to people.
Yea, I don't see why I would want to use this over google either. What makes it unique?
this guy spammed this over at pbnation too, don't bother with it, it's like google with a broken leg.
^ word. It's ridiculous it lasted this long. Someone already said that he had spammed this on another board though.
Move along, move along, nothing to see here.
Ths thread should please be put to rest,,what a crock of shizat,you sir need to focus youre mind upon somthing else.Search engines are not so simple,this is pathetic,,
Status
