Finally Michigan Gets to Buy!
Michigan PC
Finally...critique please
XFX 7800 gt extreme edition - $299.99
Biostar tforce 6100 - $75.00
3800 x2 - $320.00
Logitech 5.1 speakers - $55.00
fw900 crt moniter
what is a good hd? I cant spend more than 100 bucks or so.
Is the onboard sound good enough on the mb?
wat 2x1 gb sticks do u recomend for overclocking? Can't spend too much.
get to order this weekend finally
300gb 16mb cache (maxtor?) sata drive. good shit :)
onboard sound should be good enough with those speakers. you need really good speakers before you can tell the difference between sound cards.
and eclipse has been whoring g.skill 2x1gb for people on a budget, i think they're around like $175, so they should be pretty good.
Western Digital wd2500k, It is quieter than the maxtor's, runs cooler, and is just just a smidge slower.
Also, Mich. If I were you, I'd drop the dual-core and get some better speakers, PSU, and what not. Then, later on, since you have a job you could buy a X2 when they're cheaper and you could also possibly finance it through newegg. That's what I'm doing.
3800 x2 - $320.00
fw900 crt moniter
Why not get.
3200+/3700+ - $165/$230
XFX 7800GT -$300
Biostar Tforce - $75
Logitech Z-5500's or Klipsch/Altec 2.1's - $150
Maxtor Maxline 250gb - $100
Audigy 2 ZS - $75
G.Skill pc4000 extreme - $215
Antec NeoHE 380w - $85
I gauruntee you will not be dissappointed w/ the single core performance. You will have a much more stable rig, and I think you'll enjoy it very much. It seems to me w/ what you do and the speed games are taking advantage of dualcore's, single core is a better option for you. Also, if you don't have a monitor you can pick up a cheap MAG 17" CRT from best buy for like $75 to hold you over.
dual core wont be in games for awhile so I'd go single core 4000+ like what I got.
I prefer Seagate harddrives just because they don't break. ANd if they do break, you have a 5 year warrenty. Overall, most large companies trust Seagate and that means something to me because they have critical data. They might cost more though. I have heard of Maxtor failing the most and Western Digitial Second...(I don't include Toshiba because I only hear of laptop tosihba harddrives failing oh which I have had three go on me in 3 years).
heh thats funny, Im using two broken Seagate hard drives as coaster right now--one is a old four gig, which is ok that it died, it was old. And the other is a 160Giger--my brother sleeved his PSU, and wired it wrong, well atleast one channel he did. Hooked it up to 2 Western Digital Drives and one Seagate on that channel (every connector on that channel was wired wrong) but guess what drives are still running?
and to my knowledge Seagate dosent cover the warrenty if you Shock the hard drive or something like that.
as close to 2-2-2-5 as possible, the lowest 1gig sticks i have seen have 2-3-2-5or6
Dual Core games will probably be here early to mid 2006. I am eagerly awaiting Oblivion - Elder Scrolls IV and this will definitely support, and take advantage of, dual core as mentioned in a recent review. As new games start coming out for both PC and 360, I think we will qucikly see a need for dual core.
Gavin Carter of Bethesda recently said:
Oblivion will absolutely benefit from a multi-processor or multi-core PC architecture. These improvements have largely been driven by our optimizations for the Xbox 360 hardware. We have built a dynamic thread management system that manages processor load by our specific direction and by priorities. Portions of physics, AI, loading, audio, and rendering tasks can all be moved to different threads to keep the overall load balanced. The net result for the end user is a smoother experience.
JMHO
- JT
If you want to overclock your processor, without running a Memory Divider, than your better off getting some faster ram, like Pc4000 which normally has like 4-4-4-3 timings. Low Latency ram, doesn't mean shit when overclocking. My ram runs 2-2-3-5 and I oc'd but then only reason I got, pc3200 or pc4000 is simply because I am picky and chose OCZ, a name I can trust, over G.Skill. Good luck.
while games might not utilize dual core processors for a while, it does make the computing process a whole lot smoother. I was using my brother's computer, an Intel 830 (*gasp Intel) and going in and out (minimizing and maximizing) of Battlefield 2 and San Andreas was a lot different than when I did it on mine (loking at my sig I had a 6800 GT at the time) Maybe it was his 2 gigs of ddr2 or maybe it was the processor. But in my opinion two cores really are beter than one, if you can afford it go for it. While I experienced this on an Intel I can only geuss what it's like with an AMD... but seriously I like Intel too even if they have strong arm business tactics, they have the cheapest dual cores around.
