finally going to overclock, help
Rydawg5143
My Motherboard came with software for overclockign ( Easytune Pro) is this ok to use? What other things would you suggest? info in sig
Check out the overclocking guide and do your overclocking from the BIOS. Once you understand what each setting does in terms of voltage, multipliers, fsb mhz and the logic behind getting to a stable and satisfactory overclock, then you can actually start doing it. You can use the utility, but the majority of us don't ..we just go straight to the source (BIOS).
yeah there is a pretty good OC post on these boards that i have bookmarked, just wish i could find an easy way to print it off w/o it being 90 pages :p
