the plastic got a little scratched up (not that you can see it in the pictures so i guess it's ok), and the holes are a bit off ..but otherwise it looks good. the modling was such a major pain, but it looks good i think.
i still have quite a bit of work to do. the case came with this big purple plastic fan holder inside the case that was really handy because it was seperate from the door, so you could take the door off without having to remove the fans. you could swing it around so you could get to the insides without disturbing the fans. i really like it, but it's really ugly and blocks the view of anything worth seeing through the window, and anyway the door won't even fit because of the molding if it's in place. so i'm going to make my own that does the same thing, only much smaller and out of plexiglass.
i'm also going to be cutting some holes in the motherboard tray to run more wires behind it, and i ordered some ccfl extensions so i can get those inverters and the mess of wires away from the bottom and side of the case.
should be fun. any suggestions as to how i can clean up the wires a bit more?
