finalizing my order
wizzade
Looks good. I'd go with a 680i board personally, but that's your call.
I'd drop the Commando to a much more affordable board. However, if the price doesnt bug you, then go for it.
The dominators are a waste of money. Ballistix are cheaper, so go for those instead. Other Micron D9XXX chipped sticks would be the G.Skill HZ sticks or the Buffalo Firestix.
I'd ditch that case and get a lian li or silverstone for that price, especially since you plan on throwing the 500 watt powersupply away and using the corsair.
LOL...looks the same...How does that hsf work?
You clamp it on with some thermal paste and a fan and it cools your CPU. ;)
On a serious note it mounts like the stock Intel Cooler, you may like it or not (personally I prefer the ones you screw on) but it gets the job done. I have kept the included fan but undervolted it to 9.5V so it goes around 1000RPM and it keeps my current OC in the high thirties idle and low sixties under load, ofcause you have to weight cooling and noise, I enjoy a quiet system...
Personally I have just ordered the ThermalRight HR-03 PLUS for the 8800GTS, that should take care of my only fan smaller than 120mm and make my system as quiet as possible while maintaining current performance.
im only getting the scythe ninja until i see how my cpu oc's and until i can afford my water cooling system....which will be after my new monitor:rolleyes:
hehe, I don't have the nerves for watercooling, there shall be no liquid inside my computer. ;)
