I am about to order the parts that I need for my second build. I would appreciate it if you guys could just scan through and make sure that everything is compatible and that i'm not making any monumental mistakes. Here goes:
CPU: $114 AMD Athlon 64 3000+ 2000MHz HT Socket 939
http://www.newegg.com/Product/Product.asp?item=N82E16819103537
Mobo: $80 ASUS A8N5X
http://www.newegg.com/Product/Product.asp?item=N82E16813131569
GPU: $180 eVGA Geforce 7600GT 256-P2-N553-AX
http://www.newegg.com/Product/Product.asp?item=N82E16814130283
RAM: $80 CORSAIR ValueSelect 1GB 184-Pin DDR SDRAM
http://www.newegg.com/Product/Product.asp?item=N82E16820145505
HDD: $95 Seagate NL35 250GB 3.5" Serial ATA150
http://www.newegg.com/Product/Product.asp?item=N82E16822154414
TOTAL = $549
Thanks for your input!
TOTAL = $549
