soulesschild
- Feb 18, 2007
I know I've asked alot of questions, but I want to get things right and not have a major catastrophe that will put me off of WC forever
Here's the initial part list.
Part list:
Case: ATCS 840
Rad: MCR320 with med yate loons
Pump: MCP355 with XPSC Res top
CPU Block: Swiftech GTZ
NB Block: No idea
SB Block: No idea
GPU Block: XPSC Razor 4870x2
Tubing: 1/2" ID 3/4" OD Duralene Tubing
Compression Fittings: Buncha bitspower ones
Clamps: Worm drive clamps or whenever evil releases his clamps, hint hint
Fan Controller: Scythe Kaze 5.25 Bay Aluminum Fan Controller
What I'm cooling:
OCed Q9550
Asus Rampage (NON WC EDITION)
4870x2
The Plan:
Initially, I don't have the 4870x2 ATM so you can discount that from the loop. Not sure if I want to WC the NB/SB yet as I'm sort of tight on funds and I got the MCR320 with the fans used for about 55 shipped
I was thinking that once I added in the 4870x2, I'd probably have to add a dual rad, so that would be the MCR240 with med yates.
Right now the most expensive thing is probably all those damn compression fittings T_T.
The Questions:
1. What NB/SB blocks on a budget would you recommend? If there is no good performing blocks on budget, just say so and I'll budget for them later in the year aka after a few paychecks
5. Are these the right compression fittings to use?
7. Any issues that you guys can see?
8. Do I need mosfet cooling/fans if I have enough airflow? I know the BP has like full on water coverings for like everything on the RAmpage extreme but that's probably not in my budget for now =[
9. Thanks for reading and dealing with a WC noob
Part list:
Case: ATCS 840
NB Block: No idea
SB Block: No idea
What I'm cooling:
OCed Q9550
4870x2
The Plan:
The Questions:
