Final system, wish list, check it out...
Zeke
Alright, I got the system all worked out, check this out:
Dynapower Beige ATX Mid-Tower Case w/ Side Panel Window and 430W Power Supply, Model E22-LT - Retail
Specifications:
Form Factor: Standard ATX
Drive Bays: External 4 x 5.25" - 2 x 3.5" Internal 5 x 3.5"
Expansion Slots: 7
USB/IO: Two front panel USB 2.0, headphone & microphone ports w/ cover
Case Fans: 1x 80m; ONE
Power Supply: 430W
Approx. Dimensions: 8” (W) x 19 1/2” (D) x 18” (H) more info-> N82E16811138031 $29.00 $29.00
ABIT nForce2 Ultra 400 Chipset Motherboard for AMD Socket A CPU, Model "NF7-S V2" -RETAIL
Specifications:
Supported CPU: AMD K7 Duron/Athlon/Athlon XP Processors
Chipset: NVIDIA nForce2 Ultra 400+MCP-T
FSB: 266/333/400MHz
RAM: 3x DIMM for Max 3GB DDR333/266/200,2x DIMM for Max 2GB DDR400
IDE: 2x UltraDMA 33/66/100/133 up to 4 Devices
Slots: 1x AGP 8X/4X, 5x PCI
Ports: 2xPS2,2xCOM,1xLPT,SPDIF Out,6xUSB2.0(Rear 2),2xIEEE1394a header,Audio Ports
Onboard Audio: SoundStorm APU(Dolby 5.1) + 6-Channel AC97 CODEC
Onboard LAN: 10/100Mbps Fast Ethernet
Onboard SATA/RAID: 2x Serial ATA,RAID 0
Onboard 1394: 2 Ports by Cable(See pics)
Form Factor:ATX more info-> N82E16813127166 $99.99 $99.99
CHAINTECH GeForce4 MX440-8X Video Card, 64MB DDR, 64-bit, TV-Out, 8X AGP, Model "LA-G482" -RETAIL
Specifications:
Chipset/Core Speed: GeForce4 MX440-8X/275MHz
Memory/Effective Speed: 64MB DDR/332MHz
BUS: AGP 1X/2X/4X/8X
Ports: VGA Out(15 Pin D-Sub)+TV-Out(S-Video Out)
Support 3D API: DirectX®7.1, OpenGL®1.3
Cable/Accessories: S-Video Cable, Driver CD, Manual
Max Resolution@32bit Color: 2048X1536@75Hz
Retail Box (See pics for details) more info-> N82E16814145066 $47.99 $47.99
AMD Athlon XP 2500+ "Barton", 333 FSB, 512K Cache Processor - Retail
Specification
Model: AMD Athlon XP 2500+
Core: Barton
Operating Frequency: 1.83GHz
FSB: 333MHz
Cache: L1/64K+64K; L2/512K
Voltage: 1.65V
Process: 0.13Micron
Socket: Socket A
Multimedia Instruction: MMX, SSE, 3DNOW!, 3DNOW!+
Packaging: Retail Box (Heatsink and Fan included) more info-> N82E16819103379 $90.00 $90.00
Mushkin 184 Pin 512MB DDR PC-2700 Black Hi Perf Level II - OEM
Specification
Manufacturer: Mushkin
Speed: DDR333(PC2700)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2-2-2
Support Voltage: 2.5V-2.75V
Bandwidth: 2.7GB/s
Organization: 64M x 64 -Bit
Warranty: Lifetime more info-> N82E16820146277 $95.00 $95.00
PANASONIC JU-256A798P 1.44 MB 3.5 INCH HIGH DENSITY FLOPPY DISK DRIVE, OEM DRIVE ONLY
Specifications:
Capacity: 1.44/1.25/0.72 MByte
Average Access Time: 94ms
Interface: 34 Pin Standard Floppy Connector
Form: 3.5"
Media Type: 2DD/2HD (301/302)
Features: Highreliability/Long life with direct dirive spindle motor/3-mode model
Remark: OEM Drive Only more info-> N82E16821103505 $5.99 $5.99
Western Digital Raptor 36.7GB 10,000RPM SATA Hard Drive, Model WD360GD, OEM Drive Only
Specifications:
Capacity: 36.7GB
Average Seek Time: 5.2ms
Buffer: 8MB
Rotational Speed: 10000 RPM
Interface: Serial ATA
Features: Not specified
Manufacturer Warranty: 5 years
Remark: OEM Drive Only more info-> N82E16822144200 $121.50 $121.50
Aopen 52x32x52 CD-RW DRIVE, Model CRW5232, Chameleon Retail
Specifications:
Write Speed: 52X CD-R,32X CD-RW
Read Speed: 52X CD-ROM
Interface: ATAPI/E-IDE
Buffer: 2 MB
OS Support: Windows 98/Me/2000/XP
Features: Just Link Technology,Just Speed Technology
Remark: Retail box Includes 3 Color Bezels, Silver, Beige, Black (see pictures for details) more info-> N82E16827106535 $40.00 $40.00
Antec 80mm Blue UV Case fan,Model:77072.
Specification:
Compatibility: Case
Dimensions: 80x80x25.4(mm)
Bearing Type: Ball Bearing
Nominal Speed(RPM): 2600
Max Air Flow:(CFM): 34
Max Pressure: 0.12 Inch H2O
Heat Sink Material: N/A
Rated Voltage: 12V DC
Connector: 4 Pin
Noise(dBA): 30 more info-> N82E16835129011 $6.50 $19.50
Microsoft Windows XP Home Edition with Service Pack SP1a - OEM Designed exclusively for home computing. From digital photos, music, and video to building a home network, Windows XP Home Edition brings you into the digital age with ease. Built on the solid foundation of Windows 2000, Windows XP Home Edition also sets the new standard in efficient and dependable computing.
*Must be Purchased with Hardware!!* more info-> N82E16837102141 $91.00 $91.00
Subtotal » $639.97
If you've got it all worked out then whats the need in getting our approvals unless you have a specific question?
true. Go get a better graphics card. Maybe you can still pick up a 9500 or even a ti4200. Any of those 2 will be better than a mx440. Otherwise, everything else seems to be fine. I also doesn't look like that you have a tight budjet. Spend more money on the graphics card or else the mx440 will be the bottleneck for your system
