Final OK on parts before I order
garrityst
I think I am all done with selecting hardware for my new gaming PC for college. This will be my first build. So you all give me opinions on these parts, if this all looks compatible, and if I am missing any parts or wires or anything at all. Give any input you like!
Here are all the parts I am going to order.
Lian Li Silver Mid-Tower Case, Model "PC-60" -RETAIL
NEC 8X Black Dual Layer DVD+/-RW Drive, Model ND-2510A BLK, OEM BULK
Alps Beige 3.5inch Floppy Disk Drive, Model DF354H068F, OEM
Western Digital Special Edition 120GB 7200RPM IDE Hard Drive, Model WD1200JB, OEM Drive Only
Microsoft BLACK Multimedia Keyboard PS/2 102keys -OEM
Corsair Value Select Dual Channel Kit 184 Pin 1G(512MBx2) DDR PC-3200 - OEM
NEC/MITSUBISHI DP930SB-BK 19" SuperBright Diamondtron CRT Monitor –RETAIL
ASUS "K8V SE Deluxe" K8T800 Chipset Motherboard for AMD Socket 754 CPU -RETAIL
Logitech MX700 Cordless Optical Mouse USB/ PS/2 -RETAIL
Thermaltake W0014 Silent Purepower 480W with Black housing - Xaser Edition ATX 2-Fan Power Supply
AMD Athlon 64 3400+, 1MB L2 Cache, 64-bit Processor - Retail
Microsoft Office 2003 Basic - OEM
Microsoft Windows XP Professional with Service Pack SP1a - OEM
Creative Labs Sound Blaster Audigy2 ZS PCI Sound Card, Model "SB0350" -RETAIL
Logitech Z640 5.1 Speakers -RETAIL
eVGA nVIDIA GeForce 6800 Video Card, 128MB GDDR, 256-bit, DVI/TV-Out, 8X AGP, Model "128-A8-N343-AX" -RETAIL
So... am I missing anything to get this up and running? Do I need to order additional cables or anything? Share your thoughts, please. And thanks everyone for the help throughout this process; I truely appreciate it.
awesome, but if u want upgradability down the road say a few years, get a socket 939 board and processor amd 3500+ a64.
Pretty kicking system, but some nitpicking:
1.) I think the Alps floppy drive is like the most expensive one on some sites, like $20. I bought a Samsung $8 floppy drive. Not much difference, but really no point in spending a lot on a floppy drive as you use it only a few times.
2.) Socket 754 is a good choice now since prices are dropping while the Socket 939 line is being introduced. It's a good price point.
3.) I'd recommend not getting Microsoft Office 2003 - you can find basic replacements for most of the office programs in Openoffice.org. Also, if you're really married to MS Office, wait until you get to college and see if they offer Office at MS Campus Licensing prices for $5.
Why not an NForce3 250gb board, like the ones from Epox, Soltek, Asus, etc... Not the Neo Plat, too many problems with that board...
1. i like the choice of socket 754, because they are cheap.
2. maybe not the asus k8v se deluxe. there is no pci/agp lock and it is not compatible with all memory. i happen to have that mobo and corsair xms, so your memory is likely compatible, but why worry? i would recommend taking a second look at an Abit KV8, though i dont know if there are problems with it...
gl hf
Very nice case, I just got one myself, however let me warn you on something.
I just moved my computer from a Thermaltake Xaser III V1000+ because the damned thing weighs 40+ pounds empty. The PC-60 is about 12 pounds. I want to be able to move the thing around without a forklift, so that's why I moved it.
However, my temps went all to hell with it. The Xaser III had two side fans blowing (not much, but some) cool air from the outside to the CPU and video card. This kept case, CPU, and PSU temps reasonable. WIth the PC-60, my case temp, CPU temp, and PSU temp went up 8 degrees C. That put my PSU at about 48C, and case temp at 40C, from 40 and 32 respectively with the old case. CPU went from 54 under load to 62. (Note: CPU temp is as read from Hardware Doctor on an Abit IC7-Max3 without the tendency to read WAY high taken into account, temps are for comparative purposes only)
Because of this I have my side panel off for now, temps are back to normal. I have a 120mm fan on the way to mount on the side panel to calm things down in there.
Just a word of warning, you may find you need to mod the case to get the best performance out of it. I still love it though, light, well-built, attractive, and not too expensive.
