Final decision for build
Krilikz
This is what i have decided on for building my quad core system. This purpose of this machine is basically so i can produce music and game. The sound card and a few other things are going to be taken out of my other system and put in this build. I will be using Vista Ultimate 64 version. Comment it up!
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130080
evga 8800 gts super clocked
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188013
evga 680i mobo with wires
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145034
(2) crossfire sli ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16822144701
(2) Wd Cav 16mb 250gig (raid 0)
http://www.newegg.com/Product/Product.asp?Item=N82E16817256006
silverstone 750 watt psu 170
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
Intel quad core 2.4 ghz
Thermaltake ultra 120- extreme for my heatsink
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185006
sythe 120 fan (for exhaust or heatsink fan)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106072
light scribe sata optical drive 40$
And for case wise im seeing if i can get my hands on one of those new Xclio cases with 36cm fans
i think it´s Thermalright not Thermaltake the one who make the Ultra 120 eXtreme
no sound card ?
apart from that everything looks cool except for Vista :D
Yes, its Thermalright.
As for the build...
If you don't want to deal with rebates, go for the G.Skill 2GBNQ kit instead. You won't notice any performance difference between CL5 and CL4.
The Seagate 7200.10 320gb drives are considerably faster than the wd2500ks drives... I know, because I have two of each. As single drives, the KS avgs 52MB/s, while the 'cuda avgs 65MB/s. This will help your raid0 performance... also, seagates have 5yr warranties. everything else looks good.
FYI, that quadcore cpu will drop to $266 in about 6 months, so unless you play supcom all day and video edit, an E6600 would be better (faster), especially if you're overclocking. Also, that S-Flex fan is cheaper elsewhere, usually $14.
Oh yah, what size monitor will you be gaming on?
are seagates any louder as a hard drive? Any less reliable? The reason i went with WD is cause i know they are.
as for a monitor, im working with a 19'' nec lcd, and a 22'' Sceptre widescreen. I game on the 22''
My sound card is in the system i am using now, Creative X-fi, might not be the best for audio production but i at least got 7.1 in my room now.
as for the quad core comment, stuff will always get cheaper, i dont really mind buying it now. More apps and stuff will be coming out with quad core in a year so i wont need to switch processor out.
IMO, the barracuda drives are slightly louder, but you can't really tell if your system sits on the floor. With a 5yr warranty, Seagate seems to think they're the most reliable (WD only has 3yr on caviars).
FYI, Vista and X-Fi don't play well together. X-Fi's parents, Creative, are trying to figure out how they can fix X-Fi so it'll get along with Vista.
yea iv heard stuff about x-fi....well ill see what happens with all that shiz
thanks for the help
Another bump for the 320GB Seagate. Mine's been solid for me, plus it's the fastest drive that I've used so far.
