The wait is over! I've had some time for research and feel 85% confident in my selections, but I'm technically still a noob when it comes to a custom loop.
I plan to make the purchases within the next couple weeks, but if anyone notices anything out of place, please point it out to me.
CPU Block
EK-Supreme HF - Plexi-Nickel (EN)
GPU Block
x2 EK 580 GTX+ - Plexi-Nickel (EN)
Radiators
Black Ice SR1 480
XSPC RX240
Fans
Gentle Typhoon AP-15
Pump
MCP655 (variable)
Reservoir
EK-Multioption Res X2 - 250 Advanced
Fittings
Misc. Bitspower
Tubing
I planned on buying Primochill, but with the recent plasticizer issues I'm not sure which I'll end up with.
Main Concerns
-Will the pump be sufficient for this loop?
-Should I expect any problems combining rads from different manufactures?
-I know it's mostly personal preference, but I plan to use 7/16"x5/8" tubing/fittings. Are there any known issues I should be aware of when choosing this size?
System specs:
P8P67 - Pro 3.1, i5-2500K, 570 SC SLI, G.Skill 8Gb, Silverstone 1000w
I'm extremely excited to get this build started. I look forward to your suggestions.
Thanks
CPU Block
GPU Block
Radiators
Black Ice SR1 480
XSPC RX240
Fans
Pump
MCP655 (variable)
Reservoir
Fittings
Misc. Bitspower
Tubing
Main Concerns
System specs:
Thanks
