Final Build Selected, need last minute comp. look!
CroCop
DAW/Gaming Machine here...need a compatibility check to make sure I didn't overlook something.. thanks in advance!
Asus P5B Deluxe Atx LGA775 Conroe P965 DDR2 2PCI-E16 PCI-E1 3PCI SATA2 Dts Sound 1394 Motherboard
Liteon LH-20A1S DVD+RW 20X8X16 DVD-RW 20X6X16 DL 8X 2MB SATA DVD Writer Black Beige Retail Box
Scythe Ninja Plus REV.B Heatpipe Fanless Heatsink AM2 LGA775 S478 S754 S939 W/ 120MM Fan Adjuster
Microsoft Windows XP Home Edition OEM
OCZ GameXStream 700W ATX12V 24PIN SLI Ready Active PFC ATX Power Supply 120MM Fan Black
Western Digital Raptor 74GB Sata 10000RPM Hard Drive 5.2MS 16MB Ncq 5 Year Mfr Warranty
Seagate Barracuda 7200.10 320GB SATA2 3GB/S 7200RPM 16MB Cache NCQ Hard Drive
Corsair XMS2 TWIN2X2048-6400C4 2GB 2X1GB PC6400 DDR2-800 CL 4-4-4-12 240PIN Dual Channel Memory Kit
EVGA E-GEFORCE 8800 GTS Superclocked 576MHZ 640MB 1.7GHZ GDDR3 Dual DVI-I HDCP HDTV Out Video Card
Antec P180 ATX Advanced Mid Tower Aluminum Case 4X5.25 1X3.5 6X3.5INT No PS W/ USB & Audio Ports
Intel Core 2 Duo E6400 Dual Core Processor LGA775 Conroe 2.13GHZ 1066FSB 2MB Retail
i would get the corsair hx620 (or something like that) instead of the OCZ
Well I think I'll stick with the OCZ PSU...but..
I'm having some second thoughts on the raptor drive and if it's worth it for a DAW..I've read it was but is it really worth 190$ (CDN)..
OCZ Psu exceeds ATX spec for ripple.
Silverstone Olympia 650w is exactly waht you want. 54a, single rail, quiet. And excellent performance.
