CellBlock said:Put some water in first before turning the pump on. Running the pump dry is what causes issues.
Pour in a good bit (I'd say as much as you can, but I've never actually done this, just read up on it. If someone else says differently, I'll stand corrected.) then start the pump until the tubing you're filling gets low, then stop the pump, add more water, and repeat until the whole system is filled.
Like I said, I've not done this, but I do believe that's how it's done.
oOo sam lee oOo said:is it possible for the tube connected to the fillport to overflow?
