or better yet, you could remove your laptop hard drive and install it in your PC, copy all the files that you want and then put the HD back into the laptop
This is probably the easiest choice if you have a screwdriver around (and no router/cable).
Can they tell?well yes, but doing so, could void the warranty
Usually if removing the HD will void the warranty there will be tamper-evident tape/label on top of the screws for the plate/item.
And without knowing what laptop it is, we cannot advise which adapter to purchase. (Mini-IDE/ Mini-SATA)...
