disturbedsystem
- Jul 20, 2004
Hello everyone. I have Dell laptop that I bought used, it has windows xp pro installed on it. It has been working fine then I started messing with the boot.ini and now will not boot into windows. This is the message I get
______________________________________________________________________________
Windows could not start because the follwing file is missing or corrupt:
System32\Drivers\Ntfs.sys
You can attempt to repair this file by starting Windows Setup using the original setup
CD-ROM.
Select r at the first screen to start repair.
_______________________________________________________________________________
I want to know how can I fix this when I don't have the the original setup cd-rom. Can I use my windows xp home edition cd-rom from my desktop computer? Any help would be great.
Thanks
CD-ROM.
Thanks
