FIC Ice Cube problem
98EXL
Hey guys,
I have a FIC Ice Cube....and when I got it, the instructions said to not put in a proc over 2.8GHz. That's what I installed, and it died. I am 90% certain the mobo is toast. Everything else works fine in the case, but I want to replace the mobo in it. I can't seem to find a board that would fit into that case. Any ideas?
mini-ITX will prolly fit but I doubt the mounting holes will be the same, let alone the backplate and other things. This is why I poo on barebones systems :(.
you should check out this FS/FT thread. I think that board might have come from an FIC Cube. I messaged him about inquiring about it and he told me it was from a sff. Contact him. I bought a different board from him and he is good peepz. Good luck.
That looks good. FlexATX should work on any of those Shuttle-sized cases. You can always modify the mounting holes.
