FIC AU13 cutoff temp?
awdark
I have fic au13 mobo and a athelon 2600+ throughbred.
If I run the torture test in prime95 the temps go up to :eek: levels.. well I think it reached about 146F. I figure the board cant read the temperature very accurately so I stuck a thermal probe into my heatsink.. yeah I know it isnt as accurate but its between two fins. Right now idle the cpu is at 138F the thing says 120F.. earlier there was an approximately 10F difference..
Anyways.. I cant figure out why my system cuts off.. when it does its like I pulled the plug. I have to turn off my psu and leave it alone for a bit and turn it back on.. otherwise just pushing power makes the powerlight blink..
So what I am thinking is the possibility that the cpu got so hot that the computer turned off.
Is this how boards protect the cpu when it gets too hot? (oh yeah no overclocking)
138F is 59C which is quite hot but I dont think your comp should shut off just like that. I have the same mobo, and all the time, I keep forgetting to switch the pump on for the watercooling setup. When the cpu gets to a ridiculous temperature, the mobo will shut the system off, with a red light indicator on the motherboard staying on. If you get that light also, you know its from a overheating cpu. Give it a check next time it happens. Also, what voltage is your cpu, ram running at. Let us know what happens
-Charlie
Thanks for your input [does the boards sensors seem a bit high?]
Ohh so it isnt suppose to just shut off...
Cpu I think is default 1.63 volts ram is also default but dont know the value.
Guess the next logical step is replace stock heatsink and test my psu [the boards sensors say voltages are average... tho -12v is -13.23v]
