Fiber Optic Capacity Hitting the Wall?
CommanderFrank
Cat Can't Scratch It
According to an article in the Science report, present day fiber optic cables could be reaching full capacity sometime in the not so distant future. It’s possible that bandwidth may in fact have a finite capacity, which only further research can say for sure.
"It's likely we're going to have to go right back to the fundamentals of the optics, the actual light pipes. And if you want to develop the next generation of cable, you want to be doing that 10 years in advance, not for tomorrow."
If this was the US I would say "Oh shush, we ain't buying that the tubes are almost jammed, any more than we buy the "we don't have money for infrastructure upgrades", BS ISP's and their paid editorial writers spout while the ISP's post ever growing profit margins."
Since this is the UK, I will let some one from there handle it.
Yes, I know current fiber tech will eventually hit a wall. Tech always does, but that article read more like a paid fud piece than anything else. I might just be being paranoid though.
I always love these types of studies that relay on current technology to make predictions. Sure bandwidth is limited, according to current technology. Of course current fiber optic cables are going to have a limit, they were never designed to handle the demands of what we're trying to make them do. Especially in places of the world where fiber optic is being used a lot more. People keep championing fiber optic as this big savior of bandwidth. It isn't. Everything has a limit and thats why new stuff is always being worked on.
I'm waiting for someone to do a study that tells us "using current technology having wireless world is impossible". Be about as obvious as this is.
they have know for years that a single strand of fiber can only carry so much, thus OC48 and various labels simply mean that there are more bundles of fiber laid at the same time. Hell I still think that they should have planned to lay as much as they need or make it more accessible to upgrade.
you can run an OC48 (about 2.5Gbps) over a single fiber. Think that the fastest you will see in use in most places is an OC-192 or 10Gbps fiber.
The term OC is just for the multiple of the base speed. OC1 is 51.84Mbps, OC3 is 3 times that or 155.52Mbps
I actually think they are now able to get up to 100Gbps over a single fiber by just using a few different wavelengths to have multiple channels over the same fiber then bond them together.
I'm from the uk and i don't give a crap if there is any kind of bandwith limit to fiber, I like most dsl users sill have 56k (or 128k for some isp's) upload speeds, there is no point in talking about the limits of hardware thats hardly used in this country. only recently have BT been starting to roll out true high speed broadband in the uk and only to very small areas, only once high speed broadband is being used over the uk that this will be worth considering thinking about as knowing BT it will take a decade or more to lay more fiber.
I thought it was obvious that any kind of cable or fiber strand has a bandwith limit?
It sounds more like an article written to convey the message that consumer bandwidth should be treated as a commodity and that service providers have a legitimate reason to schedule tiers and cutoffs as they please
No, Just handled over NSN singlemode longhaul fiberplatform with current max bandwidth of something like 4TB however by next year it will most likely quadruple.
Ignore me I misread the article, but no in the states it's not going to be an issue anytime soon.
Actually I think its a ploy to give them an exuse to not replace their copper lines. We have been trying to get our ISP's to replace copper and go fiber for a while.
Heh, and we have a winna :D ^^this
Sorry, but this is pretty much meaningless. I am a techie and I want details. I don't really care about anyone else's opinion.
What are the single-strand fiber limits now? What do they propose as the theoretical limit? Why? Is there some quantum breakdown or light interference? And now that this guy has some inkling that we may be nearing the wall, that's and excuse to rush development?
Isn't DSL still getting faster? I've heard about 28 Mbps for runs less than 900 feet. I remember hearing back in the 28.8 days that POTS was nearing its' limit. Yes, DSL is a bit different, but it still uses plain telephone lines, just different equipment at both ends.
I do not know much about undersea cables, but I've never known them to run a single strand anyway. Even fiber running down the local streets is a bundle, most of it is still dark.
Well no idea what the rambling article is about, but it was always believed that fiber "can't" reach its max. The only way to get it to max out is to create no discernable space between the light pulse.
There is plenty of dark fiber that still needs to be lit up regardless of current technology.
This sounds more realistic.
It is that it is the transmission of data with light waves. The technology hasn't hit a wall, only our understanding of how to manipulate the light wave frequencies and spectrum's used to transmit the data.
Exactly. Most fiber is laid using cables with over 100 strands of fiber. A lot of those strands are still dark. What if there really is a fiber bandwidth crunch somewhere? Cables with over a thousand strands can be run in the same space. except that 864 (6x144) strand gel filled is very popular for outdoor use. ;-) Most of the cable diameter is the (often steel) cable down the center for reinforcement, and several layers of protection from weather, animals, etc. How much existing fiber is dark? There are estimates as high as 99% but I suspect the reality is closer to 80%. It is a minor quibble though, because a lot of that fiber is underused. If someone is using a dozen strands of a cable for OC-12, they could use one strand instead running SONET at OC-192, and have room for four more OC-12 paths on that one strand. In reality some of those underused fibers are running at OC-3 or slower.
I should mention that OC-768 (about 40Gbps) has been around for quite some time (like 5 years), with 100Gb Ethernet and faster comming out all time time.
Also, today's WDM tech I've heard can do 160 optical channels.
You can do the math, but you can see its not hard to start talking about Terabit speeds when talking about optics.
Existing DWDM systems can do upwards to 1.6tb/s over a single pair. I've personally seen and used 160gbit wdm links. Major backhauls between t1 isp nap's are usually wdm.
I'm at a loss on where this capacity problem lies...
The switches won't catch up to the fiber speed / replaceing copper with fiber doesn't payout NOW... maybe if they keep cherrypicking areas to install fiber they won't waste so much money
http://fibresystems.org/cws/article/magazine/35594
This is what I'm working with at the moment.
For long-haul applications the system has a maximum capacity of up to 80 channels of 40 Gbit/s and is "prepared for 100 Gbit/s"
