ffdshow (codec) config question
Easy Duzit
I often use windows media player to watch movies on my pc. One of the reasons I Like it is because it's easy to adjust the brightness and contrast of a movie during playback along with other settings. But I just installed 1Click DVD Movie and it installed the ffdshow codecs. Now when I watch a movie they usually open with the ffdshow and I can no longer adjust the video properties at all. The sliders aren't grayed out but if I try to adjust something like the brightness, I can use the slider but it doesn't affect anything and as soon as I release the mouse button, it just snaps back to the original setting. These movies all played fine with the codecs I had prior to installing 1Click DVD Movie so here's the question. How can I disable ffdshow and just use the codecs I had before that? There is a configuration settings screen I can get to in the All Programs menu for ffdshow, but I have no clue as to how to make it not be associated with my avi files. All the options are pretty cryptic. And if I do disassociate it with my files, will 1Click DVD movie still be able to use it if it needs it?
Help!
Easy Duzit
