Few things I need help with, quick questions
Bleedblue12345
Hello, I have a few questions, im pretty sure this is the right forum.... anyways here they are...
1. What are they keys for entering the bios on the dell l866r.... any help here would be appreciated.
2. I cannot share my drive on this computer with another computer, and whenever i try to access it from another computer, i get an error saying that i might need more permission. Any ideas on this one?
Thanks a lot
1. Not sure which, but to access bios usually is either the F2, F8, F10 or delete button. It should say when you boot.
2. If you have firewalls in the way try disabling them. Then if you can share you know its a firewall issue and you'll need to set up rules.
Every Dell I've ever owned used F1, go figure. Strictly laptops, however, so I'm not sure about Dell desktops.
I just checked and I was wrong, it's F12? At least on the 10 of them we have at work it is.
