Few questions on new system
sorinj08
Hi
(longer post - thanks for the patience)
I'm building a new system (with a friend's help...I'm not that skilled...yet) and have already acquired most of the components but have a few questions as - I still have 2-3 days for returning most of the stuff, they're still sealed.
The system will be used for gaming, photo/video editing (not professional..but hobby), (myself) and Autocad (professional use....my wife)....and of course all the other usual lighter stuff
1. I opted for the ASUS P5Q-E as a good price/performance/updated/(mid) future proof board. Apart of the other features - I was really happy getting the Express Gate. However I didn't realise that using that on this board you'd need to give up RAID configurations - which I really wanted for mirroring - RAID 1. As it stand - I have to go to to the Deluxe version so I can have the SSD Express Gate. The question - is Express Gate THAT usefull/nice/important to make me spend another $40 CAD for the P5Q-Deluxe?....the other option is to give up RAID...which I'm not keen...or to just ignore the Express Gate and keep the P5Q-E.
2. I bought 2x1Gb OCZ Reaper 1066 8500 - that because I intended to keep my XP Pro (32 bits). Since then I read a few opinions that even if the XP won't recognize all 4Gb - it's still better to use 3-3.5 instead of 2Gb. I can still swap my set with a 4Gb - if you think I'll be better off....I'm not that keen to spend on Vista (64 bit) yet...Or 4Gb doesn't make sense at all if not using a 64 bit OS...
3. The last one might be silly....but I read in the ASUS on-line manual that for RAID with XP you still need to make floppy disc - in case something happens....I didn't even think anymore of the floppy drive...They say only with Vista you could use an USB flash drive...So floppy really necessary?...
The other components:
E8400
Visiontek 4850 (with free Grid game:))
2x WD 640Gb (intended for RAID 1...see above dilema)
PC P&C 750W Silencer (might get another 4850 later....so just to be sure the PS won't need to be changed)
Antec Nine Hundred
Some LG DVD-RW....(couldn't believe I paid now $30 for something that 3 years ago I paid ~ $150)
Thanks in advance for your help.
Hi
To be more precise, you can’t run Express Gate installed on a drive running ACHI mode and RAID enables ACHI. I like Express Gate and if it were me I would opt for the SSD. I understand you can install Express Gate on a USB key, but I couldn't get it to work. You could also run it from another drive outside of your RAID but that wouldn't likely be cost effective.
Memory is getting so cheap, I'd prolly get the 4GB and not have to hassle with it.
You can build a floppy emulation on a USB key. I built one and have it handy. I flashed my gfx card with it. HP offered the program free from their website.
Thanks msabo, looks like I'll change to the P5Q-Deluxe and get the 2x2Gb kit. Now I also understand that it might be enough to get the 800 PC2 6400 kit instead of the 1066/8500? I could get the same Reaper but with better timings 4-4-4-15 for quite less...and almost would compensate for the more expensive MB....
And...I didn't find the HP link to the free SW offer.....do you happen to have it....
Thanks
Thanks
For me 1066 was a minimal adder. Whatever you do, select your memory from the QVL. Do you have the QVL for the P5Q-Deluxe?
Here's the instructions for creating a floppy on a USB key.
Here's the P5Q-Deluxe QVL.I suggest you choose memory verified for A,B, & C on the chart. I see OCZ listed, but you need to check the exact part number to be sure. This may seem like a lot of hassle, but this could save you a lot of time and effort in the long run not having to deal with memory compatibility issues.
