im looking at the swiftech h20 220 kit
dual 120mm rad, 650 pump etc
when it says the pump needs to be primed, does that mean water in the res filling the tube going to the intake so water is ready to go soon as its turned on? i know some pumps need to be run through their cycle by hand to prime them before power
also, since the res isnt that big on the kit, should i fill the res, and rad with fluid for startup? im assuming the air will work itself out in the resivoir?
anything else i should know.. i plan on builing the kit in an external box cooling only the cpu
heres the kit im referring to
