Chowder Head
- Oct 20, 2005
The deal over at jab-tech looks very very good, but I'd not sure which options, if any, are worth it. Here's the link for reference. http://www.jab-tech.com/Scythe-Ninja-SCNJ-1000-pr-3130.html
1. I've heard the 120mm Loon fans were great and for only 4 bucks, you can't go wrong. However, I heard if you were using a Ninja in a P180 (which is what I plan to do) you could go fanless if you wanted to, due to the cases great cooling. Any thoughts? Or for 4 bucks, should I just grab it?
3. About the fans, why is there an option for 2 fans? Can you really find two fans with the Ninja? Is it worth it?
2. What exactly is the "article clean?" Is it perhaps something you use to take off the thermal compound when you want to change something out?
3. Regarding the compound, once you apply it install it, it sorta "burns" together and if you were to change out your heatsink for some reason, you have to apply a new bead of the compount, correct?
4. Lastly, I've been hearing people running fans a lot of things for the P180, so if were I to order two of the Loons, could I use one for the heatsink and the other one for something else, or are those fans specifically designed for heatsink use?
Any help is greatly appreciated, thank you!
