Is it recommended now to install the vCenter Converter on the machine you are doing a P2V from or is doing the remote agent install and doing it remotely still ok? I read a few months ago that they were dropping support for the remote agent P2V or was that only for the plugin with vCenter Server? I am confused because the new vCenter Converter 5.0 still lets you do this so i assume it was just the vCenter plugin that they are dropping?
For P2V conversion what are some services you should stop on the machine? and when you are doing a domain controller or something like a small business server how do you make it so no changes are made to the system or does the converter agent keep track of changes right up until the end?
